plumbinghelp1
Hi, I am throwing in the towel. I have been making adjustments on the American Standard 4370A toilet with the Vormax dual flapper and am unable to get the bowel to flush completely. If I press and release the handle, the flaps seem to close too early and the bowel fills up but doesn't go down. If I hold the flapper down, maybe that works 20% of the time. If I press once, let the flappers fall after 3 seconds, then raise them again, that works about 30% of the time. It did work when initially installed 8+ years ago. The toilet's original arm broke and I replaced it with the adjustable one from home depot and regardless of where that is set to I run into the same issue of the bowel not clearing. I included a video below. If I can't figure this out, I will replace the toilet at this point. I appreciate any assistance! Thank you! JT
