drco
We discovered a bit of water coming out from under the concrete in one of the basement rooms.
A contractor dug a hole and found more water under. The water is not overflowing. We would vacuum the water but more would come up, bit it doesn't overflow. From the surface of the water to the top of the concrete floor, it's only 2 inches.
We tried hydro flushing on our perimeter drain and also did camera and everything looks fine. No blockages.
We tried shutting off the main water valve. We only shut off for 3 hours as we are not sure if this will have a detrimental effect on the water heater. When the main water is shut off, the water still rose but seems to rise slower. Hard to say if this is just die to residual water in the pipe or from the water heater.
We are using baseboard heat.
Any ideas on where this leak is coming from and how to troubleshoot it?
I'm not a plumber so hope you will be patient with me
Thanks for your help
