stuntmonkey
I'm finishing out a rough-in half bath in my basement, and I was hoping someone could fill me in on what the red plastic mystery object around my soil pipe is in the picture below:
Is it a sleeve that the original builder put in place to keep debris from getting wedged between the soil pipe and the concrete? If so, was it intended to be removed or cut away prior to installation of the closet flange? It doesn't appear as though the closet flange would fit around the soil pipe otherwise.
Originally, it had some concrete mounded up around it (see image below):
I knocked the concrete away thinking maybe they had already installed the closet flange (which the red plastic mystery object turned out not to be, since it doesn't have any holes in it for mount points). Bonus points if you can explain what the point of the concrete ring was.
Thanks in advance!
Thanks in advance!
