To the Forum
I live in a hilly community where the water pressure delicvered tho houses varies from street to street cepending on elevation. I measured the static water pressure to my house from a community well at 82 psi. Recently, there has been severral plumbing failures because of the high water pressure.
I intend to install a pressure reducing valve in the system.
My opions are to install the valve on the output side of the water meter at the curb, the meter is situated underground, in a fiberglass box that quickly fills with sand.
My second option is to install the meter on a 1.5" diameter x 24" long vertical PVC pipe that feeds my Kinetico water solftener that is situated outside. The meter will NOT be buried and there is enough room to use unions so it could be easily replaced
The water softener feeds all the plumbing in he house except for the 9 zone lawn sprinkler system.
Installing a pressure reducing valve that would include the sprinkler system would mean a lof of digging for a 90 year old man.
My concern is that the sprinkler system undergound valves will NOT be able to tolerate the 82psi, (78psi when running) for a reasonalbe amount of time.
Any and all comments are welcom.
Bill
Bill
