1776Raider
Greetings,
I just recently purchased a home built in 1953 and there are a few things going on. This is one of them. I replaced the utility tub downstairs and turned the water feed valve to that side of the house off and when I turned it back on the old valve began to leak. The lone valve behind the water heater is the one. There is about 15’ of galvanized piping left, the rest is PEX or copper. There is also a leak I found when looking at the main water valves. Any suggestions on how to go about this? I am thinking of installing sweat copper Ts and soldering. I have become pretty decent at soldering copper pipe. Is this a bad idea? Should I use threaded connections? Like what was originally done here. Just seems that the only places that leak are threaded so my thinking is soldering is a far superior method of attachment if possible and done correctly. I’m also unsure of what this random spigot is. Is this a relief of sorts? A drain for when work is being done?
