Aaron Carl
I'm hoping someone may have a guess on what might be causing this sound? Please see the link and listed to the audio. I help my phone up against the pipe a few times to get louder audio.
https://drive.google.com/open?id=11uo692xU5yF5HaYxNqcKt7MIhvIfFpVN
This is right at my house water entry point, the noise fades dramatically as I walk away from this location. There is a meter and stop valve in a pit at the street, utility company says it all seems okay and say it's from my plumbing somehow. I had the main house valve and PRV replaced and it's still doing it. Typically it does it when there is no water flowing in the house, and is not associated with any on/off operation of plumbing fixtures (water hammer). When I shut off my main valve the noise stops, and continues when I turn it back on. The closest plumbing fixture is an exterior hose bibb about maybe 6-8' away. Water pressure comes in at about 80psi, and is regulated down to about 65psi. We have no noticeable issues with water service or pressure. The noise is very intermittent and unpredictable... but is driving us absolutely nuts and has been going on for a long time to different degrees. Any help would be very appreciated, I do not want to keep throwing money at plumbers and not fixing the problem.
Thank you!
Thank you!
