Looking for an in-line mechanical timer for PEX
krmarshall
Mar 29, 2015
Problem: More times than I’d like to admit, I have turned on the water to my outside water feature and then forgotten to turn it off.
Water is currently controlled by a simple manual ball valve on a PEX line. There is just the one destination (not irrigation).
I’ve searched for mechanical timers, but they are all for garden hoses. Ideally there would be one made for PEX and sharkbite and based on gallons or minutes. But I’m not picky if I can actually find something that works!
Thank you.
Can you tie it to a sprinkler system which has a drip system installed? You could allow one zone just for the water feature, and adjust it accordingly.
I did this on a mister once 12 volt mechanical timer hooked to a sprinkler valve it worked great
