captaincanuck
My father's house has a basement (with a concrete floor) and the main drain pipe is leaking at the floor, it is not coming from above. He has tried to put sealant all around the base of the pipe at floor level and it still is leaking. It's almost like there is pressure in the pipe, but as far as I would figure there should be zero pressure in a drain pipe. Why the leaking? Thanks in advance...
