Hi,
I read the other thread about an under slab leak, as I have the same issue but mine is different...
I have 1 drain line coming into the 4inch/cleanout directly above and there is no other drainage lines within 20 feet of this one, it leaks within 4 feet of where it goes into the ground after about 3 minutes of running water.
It comes out of the crack/space between the slab and footing wall. It oozes out pretty slowly so am I right to assume it's within a few feet of where it enter the ground for it to appear so quickly/only in the 1 area? It only leaks when I use the sink above-no other plumbing fixture in the house will cause the leak even if I leave it running for 15 minutes (I turned on every other tap in the house to check) as I'm cheap and don't feel like paying $400 for a camera.
My jerry rig plan is to knock up the concrete around the drain .. starting with about a 4 foot section, then run the water until I see where it comes out, isolate and replace that section... Am I crazy, stupid, etc... is it possible this will work? I have no problem cutting/redoing the line and concrete - I'm in the middle of basement renos and thought this would be the best time.
I'm redoing the basement as a present for my mother, and quite frankly, don't want to spend $2,000 if I can get away with doing this myself
