Tumbleweed
Is the Kohler flush canister prone to malfunction and requiring replacement ?
Have this Kohler Wellsworth toilet maybe 5 years in service. About six months ago the toilet started exhibiting some intermittent running (filling of the tank). On first inspection I noticed the chain between the flush handle and the canister had no slack. Making a more detailed inspection the handle has the normal range of motion. The canister had rotated counter-clockwise taking up the slack in the chain. The tension of the chain causes the flush canister to not seal properly.
Holding down the flush handle for four or five seconds during a flush cycle, upon release the canister will return to a position where slack is present in the chain. Two to four days later (after many normal uses) the canister has rotated to a position where the chain is taught again, the canister is not seating properly, thereby causing a slow drain into the bowel, and the fill valve is running intermittently to restore the water level.
Is this a known flaw in the canister design ?
Short of replacing the canister assembly (sigh) is there a fix for this issue ?
Thank you in advance.
