IGoCougsI
I have a new house that has a shower with a single handle that operates the overhead shower and then there is a separate single handle that operates a hand wand. Both are of the same style and manufacturer is Kohler. I suspect they are 15 years old...same as the house.
Problems:
Thanks!
IGoCougsI
Problems:
- The overhead shower, when the hand wand is not on, doesn't get that hot.
- The hand wand, when turned up to hot, doesn't get warm at all. (this is true if used alone or used when the overhead shower is on at any temperature.)
- If I turn on the hand wand to hot and the overhead to hot, then the overhead shower gets to top heat but the handwand continues to be at a cold temperature.
Thanks!
IGoCougsI
