Out of nowhere the valve below our kitchen sink started spewing water tonight.
After clearing all the cleaning supplies stored there we determined it came from a round part in the middle of the connector piece on top of the cold water valve.
It appeared a tube got disconnected from it.
The black cold water valve in the first image (the one with text) has a brass nut (I'll call it V1) that connects to the thick brass part with the white sealing tape (V2). In the middle the round thing sticks out (V3) with a nut around it (there is a side view of it in the 2nd picture), and on top of it there is another nut (V4) that connects to the white grey tube (another angle is in the top right of the 3rd picture).
And there are two tubes we found under the sink that are disconnected:
The red one that comes from the sink above it in the 3rd and 4th picture (I'll call that T1)
The clear one connected to the left side of the Watts 5 year water filter in the 5th picture (T2)
So here are my questions:
- Which hose/tube do you think is the one that got disconnected, T1 (red) or T2 (clear)?
- Would I be able to reconnect it by loosening the nut around V3 and tightening it again after attaching the tube?
- If not what do I need to do to reconnect it? If I need to replace any part, what is the name of that part?
- To get easier access should I loosen nut V1, nut V4, or both?
Thanks!
Thanks!
