Tom the Elder
I recently had a very similar repair done. My entire loop was copper, leak was on supply side of valve, and the loop included a hose bib. For me, replacing entire loop outside the wall cost $500. Job took about 2 hrs, 3/4 of which was spent clearing water from pipes so they could be brought up to temperature for solder (whole house seemd to drain to this spot - repair could not be done while pipe dripping). That means if you hire a plumber to use copper to replace the leaking section, and if you can get one who will work by the hour instead of quoting for job, drain the line as much as possible before they arrive.
