rajsingh
Hi,
I have a pitless adapter about 3.5 feet into the ground. I'm trying to pull out the pump and I made a T handle using three 1 inch black pipes and a 1" tee, but I was unable the pull it up.
Is there any screw that I need to unscrew before pulling up the pitless adapter and the well pump behind it. The pump is about 80 feet deep. The pitless adapter has a 1 inch pipe screwed on it that comes out all the way to the top.
Three years ago, a friend of mine said they had a professional come to pull out the pump and they put a pipe inside to unscrew something (they have a similar set up), but I can't find this tool anywhere and also none of the pitless adapaters at Lowes have any screws on top. My friend took a picture of the tool and I'm attaching its picture here as well.
Any thoughts on how I can pull this up?
Thanks
Thanks
