Bird Doo Head
When looking at closet flanges, PVC and stainless ring, for 3" schedule 40 pipe, I noticed that none would be able to meet the finished floor if the riser pipe was cut flush with the finished floor. (Excepting perhaps the inside-the-pipe twist & seal which I didn't look at)
The stainless ring type is flared out. In a 4" hole, it will stop about 3/8" above the floor. One needs a 5-1/8" hole for it to sit flush, but then there is no floor left for screws to anchor the flange.
Actually, that is enough of a rise that my American Standard's short skirt wouldn't allow spacer rings under the flange. It will hold the toilet in the air.
The PVC over-the-pipe one has a ring inside the socket that stops the pipe before the flange can meet the finished floor if the riser pipe is cut flush with the floor. It holds it about 5/16" above the
finished floor. In my case, I can use that and turn the ring off in the machine lathe. But, knowing me, there must be something wrong with that plan...
What's the normal rough-in procedure?
When roughing-in before the finished floor is installed, how do you guys know how high to cut the riser?
When the finished floor is in before you set the flange, and the riser pipe is stubbed up tall, how do you proceed?
Thanks For The Education!
Paul
Paul
