BikeRider64
While recently trying to install a new wand showerhead onto the shower down pipe, I noticed that the male threads on the end of the pipe were pretty worn and I could turn the plastic female part of the showerhead continually without enough resistance to make it impossible to keep turning it (at least without enough force to strip the plastic threads). Using white teflon tape I could just make it tight enough to avoid leaks, but I could sense that I could turn it further if I tried.
Additionally, we needed to lower the new showerhead enough so it wouldn't be a tough reach, so I bought a 7" brass shower pipe extension, but when I tried to install it, the connection was even looser than with the plastic part, and no amount of tape would solidly connect the two pipes.
I assume that the correct solution would be to replace the down pipe with a new one with good threads. But we rent and I'm pretty sure that the landlord isn't going to be willing to hire a plumber to do it (long story not worth getting into). Plus it's a 65 year old apartment and the pipe looks original, and if I try to replace it myself I'm concerned that I'll break it off inside the wall and thus require making a hole in the wall to fix it and all the complexity that this would entail. When I gently tried to unscrew the down pipe, it wouldn't budge, so I didn't proceed further.
I'm wondering if it's possible to either repair the threads on the existing pipe, using a die and wrench with cutting oil, or perhaps some sort of thread repair compound if there is such a thing, or coat the threads with something like Megaloc or Real Tuff and maybe tape as well? The pipe appears to be either brass or steel. There's a greenish patina on parts of it, which suggests brass to me. It's likely also from the mid-50's. Any chance it's copper?
Basically, I'm looking for the least "intrusive" solution that actually works. If none exist, then I'll just reinstall the old showerhead, which for whatever reason does make a tight fit with the pipe, and just live with it. Hopefully though there is a solution that would work.
