How to connect Valve to Transfer Switch When 9/16" off!
KevinAndrews
May 16, 2013
They say a picture is worth a thousand words... Please open below and scroll to the second page. On the top right corner there is an "Example" picture.
http://www.moen.com/shared/docs/instruction-sheets/ins1972a.pdf
That's what I am trying to install. As you can see, the 1/2 copper pipe coming out of the valve (bottom) and going into the transfer switch (top) are shown to be 9/16" off. Is there a copper fitting that can handle that?
I wish instructions were better!
Thanks
A copper street 90 into a regular copper 90 would give you a touch more than 3/4" offset, a street 45 into a regular 45 would probably give you less.
If the two valves are far enough apart, soft copper would be a better resolution.
Thank you.
The two valves are about 7" apart. One is above the other... Did you have something like the following in mind?
http://www.homedepot.com/p/1-2-in-x-10-ft-Copper-Type-L-Soft-Coil-PCLE-375L010/203654407,
What is the minimal distance and would it get soldered like hard pipe between the valves?
Yes, that is what I am talking about. I have seen it available in as little as 18" pieces in HD or Lowe's.
I haven't worked with soft a lot, but I am thinking that 7" center to center would be a little tight to get a 9/16" offset.
Yes, it would solder in place just like hard copper.
