trhoppe
We had a contractor screw up our shower drain. I didn't inspect his work before he closed up shop on the shower itself, and I trusted him as he's done other good work before. Now we have a fully tiled shower and this problem of no P trap.
Need to figure out how to fix this, considering I basically don't really have good access. I was able to cut a 12x16 or so hole in the floor NEXT to the shower, and can kind of reach in there, but barely. I definitely can't reach all the way to the drain in order to remove that rubber 90 degree fitting and install a P trap there.
Is there a good way I can somehow install a functioning P trap in this setup?
This is the picture of the actual shower drain coming down from above. That rubber 90 degree fitting that disappears into the subfloor is installed on the linear drain itself.
This is a picture slightly further downstream. Here you can see the drain the background. In the foreground is the vent and I'm taking this picture from right next to the toilet, where I was able to cut a hole in the floor.
