thegeeps20
Hi all..first post. I run a greenhouse business and would like some input on an ongoing problem with low GPM from my submersible pump.
Background:
-artesian Well is 180', pump about 160'(produced 10GMP when dug 20 years ago, refrac about 6 years ago, don't know the GPM.
-high Iron! Lots of rust.
-Goulds 1/2 HP 10GPM, 230v pump
-I've never run out of water, even when running 5-6 hours straight(see below)
-depth to water in well when pump not running..a guess would be 50'
-pump not short cycling at all
-voltage reads 220 at pressure switch.
-Piping runs about 6' underground from pitless adapter into a "pit"(where there is a faucet to drain during winter), From there another 5-6' to a Weltrol tank inside a greenhouse.
- the well pump pumps to the Welltrol tank then about 15' of 3/4 hose from the welltrol tank to fill a 1,500 gallon holding tank.
-I irrigate using a booster pump that pulls water from the 1,500 holding tank. I water 5-6 hours straight most days in April-June. So, the submersible pump is running constantly filling the 1,500 holding tank as I irrigate. I then have it fill again on a timer overnight.
-Booster pump is pushing water at about 10GPM
-3 years ago put new pump in well, was getting 7.5GMP from Weltrol to storage tank.
-Last spring I measured my output from weltrol tank into the holding tank..only 4GMP. I pulled pump and intake was pretty caked with rust, cleaned out and replaced piping and wire in well.(rust build up inside of old pipe) and GPM increased to 6
-this spring output was back to 4GPM. I pulled pump and intake didn't look that bad, decided to replace pump again with brand new Gould's 1/2HP, 10GPM..exact same pump I put in 3 years ago that immediately gave me 7.5GPM. This time though, only up to 6 GPM. Very disappointing, thought for sure I would be back to 7.5 with new pump.
-So..I would like some input on what might be happening. I'm not sure the well pump is adequate. I tried to understand the charting, but got confused on the PSI part and what I needed. Goulds chart shows depth to water up top and PSI(0-60) on the left to determine the GPM. What would be the PSI in my situation? My pressure switch is 40/60, but isn't that irrelevant as the Weltrol tank runs out in a few minutes as the holding tank is filling. The faucet is wide open and the well pump is running constantly from this point on for 5-6 hours to fill the holding tank.
- I should note that when the pressure gauge hits the kick in of 40 PSI, I hear the click and the gauge immediately drops below 10PSI. I believe this has ALWAYS happened from day one. Weltrol tank bladder seems fine, holding air pressure(about35) below cut in pressure. The faucet is wide open from Weltrol tank with 3/4" pipe about 15' long straight into the 1,500 holding tank. No short cycling of the pump.
- I'm thinking 3 thoughts....1)I need to match the well pump better..maybe 3/4 HP? 2)the piping from the pitless adapter to the side "pit", then up to the Weltrol tank could be caked with rust and slowly building up over the years. Again, I replaced the 160' feet of piping to the pump to pitless only.
3)the well is not producing what it used to causing the water level to be lower in the well meaning well pump would produce less GPM than in the past. However, even running 6-7 hours straight, I've never run out of water...so this seems unlikely.
-sorry for the long post, just wanted to give all issues I can think of. Bottom line, I need the well pump to be able to fill the holding tank at around 6-7GPM so when I'm watering from the booster pump(10 GPM), the holding tank doesn't run out too fast.
-Key fact-3 years ago, new well pump pumping 7.5GPM into holding tank via Weltrol. This year, replaced with brand new exact same model and only getting 6GPM. This after replacing new piping in well last year.
any input would be much appreciated.
Background:
