They're having pressure issues, most likely debris in the stem. Just wanted to get an idea of parts availability before I attempted to take this apart. I thought Kohler as well upon quick inspection, or even Brizo, just haven't been able to lock down a confirmationKohler price pfister made spouts similar in the 80’s.
I think Delta even made one similar. It’s not Delta.
I don’t think it’s Price pfister
it may be Kohler or a company like Rohl that’s copied the style.
What’s parts do you need ? The cartridge is likely a generic ceramic stem.
And yes, I checked the aerator lol.They're having pressure issues, most likely debris in the stem. Just wanted to get an idea of parts availability before I attempted to take this apart. I thought Kohler as well upon quick inspection, or even Brizo, just haven't been able to lock down a confirmation
Strictly cold side. Very hard water. Deposits maybe? Wire brush to clean with stem replacement is my hope but was hoping to identify and have parts on hand before diving in. May let this post sit a while and see if I get luckyI don’t think it’s Brizo.
With the aerator off the flow volume should increase when you run both hot and cold water versus just running either hot or cold.
If flow volume doesn’t change ( it’s low no matter what ) then the obstruction is in the tee under the spout or in the spout. Most likely
The cold side is spurting when first opened as if it's losing water pressure and draining back. Cartridge or stem should solve this as it should hold pressure to prevent back feeding from single lever faucets elsewhere throughout the home. Just hoping for identification if possible. Pulling stem may be the only way to identify, unfortunately.could be in the stop valve below.
Could be the cartridge in the faucet.
Might be a collapsed/ kinked hose leading cold valve to the spout tee
I’d start at the stop valve and work my way up
