I have a slot sink drain, cannot access drain from the top, the pan/box is enclosed. Any ideas on how to fix?
Top of Sink
It looks like the drain pipe was installed before the box below was constructed, but the flange disconnected from the rest of the drain pipe(that is missing) leaving no way to tighten a rubber gasket. This is a used/returned vanity that I picked up and it looks like someone tried to unsuccessfully use silicone at some point.
Drain hole from under sink, cannot access from the top
Came up with this, basically sandwich the following below with some industrial strength adhesive? (needs to be thicker to seal properly @ the bottom)
Anyone have any other ideas?
Top of Sink
