Hi, we had our furnace replaced with a condensing one (I think thats what they are called, I lived in the UK for a long time and thats what they called them there...) anyway it vents water and CO2 out a pvc pipe. The pipe leaks at a join. we have finished our basement since/during this so saw a wet patch in the ceiling and cut it out and exposed it all, cut some bits out put couplers in, but it was very tight space, multiple couplers there and it started leaking again after a year. So, its a straight shot outside, going to cut out the bit with couplers and replace it all the way to the vent outdoors so there will be only one coupler and I can get a clean start...
While I am doing this, I am curious. It is 3" PVC pipe right up to nearly the outside vent and then its reduced to 2" and connects to the outside vent assembly... on the charlotte pipe website it says "DWV application diameter cannot be reduced downstream " this vents water out, so downstream would naturally be towards outside of house in my small mind, and it is being reduced from 3" to 2" on its way outside is this legal/correct or am I thinking backwards... the vent pipe rises on the way out, so the furnace is lower that the vent, so maybe that is downsteam. While I am ripping this out, if something wasn't done right, seems like the time to fix it... but the vent on the outside of the house is obviously made for 2". Thanks for any advice!
