CABrouwers
A drain pipe in my apartment gets regularly clogged, and I wonder how I can prevent it from happening.
I am also curious to understand what might be happening since some of the symptoms sounds rather curious to me.
- The apartment is located in an old industrial building, and most pipes run under a raised floor.
- A 4" pipe connects two adjacent bathrooms to a riser. The distance is about 25`.
- Each bathroom includes a wall-hung toilet, a bathtub, and a sink.
- My recollection from construction is that the pipe meets the minimal slope requirement of 1/4" per foot.
- Any change or repair to the piping would be very costly, as it would require removing the tilework and/or the wood flooring.
- The clog is usually announced by gurgling in the toilets bowl (Why?).
- the water level in the bowls becoming very low after a flush also seems to announce a clog.
- A plunger can't beat the unclog, but it does manage to empty the bowl. Strangely, I can usually flush and empty the bowl repeatedly by actioning a plunger, so the water can get thru. Water might back up in the bathtub but usually drains within minutes.
- Sometimes using actioning a plunger in one toilet makes the other bowl empty (?)
