I feel like my pipe that runs from my well to my house is partially blocked, but I didn't know if that was even possible. I figured that if water could break through a blockage, it would eventually clear it out or the blockage would simply stop water completely. Here we go.
I have an old well system. I have the pump and the bladder tank above ground in a doghouse looking thing approximately 30 feet from the house. It has a heater in it to keep the pipes from freezing. I replaced the pump a couple of years ago because it stopped running.
Water pressure dropped a couple of months ago to the point where I need to put tape on half of the shower head for it to shoot water out instead of just drip down. I assumed the pump was going bad again so I was going to wait until it got real bad to fix it.
The water pressure usually starts decent when turned on and they slows way down after about 2 minutes, but we still get water. turn the water off and wait a couple of minutes and repeat the process. Now the water stops almost completely and I have to turn it off and wait a couple of minutes.
I went to the doghouse and I noticed that I still had 45psi on the gauges. I went in the house and turned the faucet on in the kitchen and the water runs, slows, and stops. I left the faucet on and I go back outside and the gauge has 40psi and is dropping very slowly. I stayed out there for 15 minutes just to watch the gauge drop to 20psi and the pump kicks on and goes up to 48ish psi. I go in the house and the water is still just trickling. I turned the water off for a couple of minutes and then turned in back on and it runs for a couple of minutes.
I went to my basement and turned on the water spigot where the pipe comes into the house from the pump and it runs about 2 1/2 gallons of water before it stops to a trickle. I haven't noticed any color changes in the water. I have no water softener, but the problem seems to come from before the water runs into the house anyway.
I should also note that you can hear air shooting out when the water is turned back on, even if It doesn't run completely dry before I shut it off.
Sorry about the book, I just like throwing my information out there all in one shot. Is this a clogged pipe, or is there something else I can't think of causing all this?
