Taulant1995
Ok so I have purchased a Simer 3963 1/2 HP cast iron sewage pump and have already installed it in the pit. I measured the diameter and depth of the pit. So the diameter of the pit is about 19.5 inches and it's about 25 inches deep. My dad had to shorten the length of the float switch a little so it doesn't get hung up on the wall of the pit. When the pump turns on, it stays on for 4-7 seconds before shutting off. I have to do a test one more time with the timer and see how many seconds it stays on before it shuts off again. Does it count as short cycling if it stays on between 4-7 seconds? I'll update this post God willing when I get an accurate time of how long it stays on.
I have attached a picture of this set up. The bathroom hasn't been used in a while and we also went through a storm last Friday which "cleaned" the pit up leaving just water. It's only been used to test how the new pump would work. It's not the usual type of sewage pit with two pipes coming out of it. This one is located under the bathroom sink and we found the pit like this when we bought the house in 2003. This pit does have holes on the sides but we never smelt any sewer gases or seen any sewage leaking from the pit(there is a small opening in the laundry where it lets me check under this bathroom with the pit and it's always been dry). Maybe the holes aren't drilled all the way through.
