Condo bathroom sinks drain saga... help needed
quenellefl
Jul 1, 2023
Florida
Hello folks. I live in Jax, FL and here's my story.
I’ve had a long history with my bathrooms’ sinks on the 2nd floor not draining well. They were already slow draining from the time I bought this condo 1.5 years ago. But overtime it has gotten worse. They would completely clog after a minute of running water.
I probably have spent around $50 altogether on Draino to get them working in the past.
When I plunge the drains in those bathrooms – weird stuff from outside would come back – leaves, small twigs, sand – figured out there must be some sort of vent on the roof that is broken and lets all this garbage in. I do have a massive oak tree overhanging my condo building.
Sort of have given up on those sinks for awhile.
Finally there was the HOA meeting about a month ago. I spoke to the officers and they agreed that this is the HOA’s responsibility since it’s coming from the outside.
2 weeks later they have sent a plumber to take a look. They guy didn’t feel inspired to climb the roof all by himself. He tried to use his standard 25’ rooter to clear the jam – failed. He agreed that this is something called “common line” that is jammed and it needs to be cleared from the ceiling.
He talked to the HOA manager on the phone and it was agreed that it will be faster if I were to hire a more advanced team of the plumbers to deal with it – to be later compensated by the HOA for the bill.
The guy recommended the David Gray or Duck Duck Rooters.
I have called the David Gray – they wanted $65 for the assessment visit first even though I have told them what the deal is.
Then I have scheduled the Duck Duck guys on this past Monday, took the morning off at work.
Told them that it’s a climb on the roof kind of deal when was making the appointment.
Told them that again in the morning on Monday on the phone call confirming the appointment.
They were suppose to come between 8-10AM. They would call 30-40 min prior to confirm.
Right.
Got up at 7 am like an idiot.
Nobody calls me.
Called them myself after 8.
The dispatch was like, hur-durr, the other team has already taken the long ladder. They should be done by 10.
Finally 2 vans arrive. At 11:45.
They looked at my roof and were like – our ladder won’t reach there.
/facepalm
Ok, we’re gonna try to clear the jam with our advanced machine.
2 dudes.
Went in rooting out from the bathroom sink drain pipe again.
After awhile of drilling, they have broken off the tip of their “snake”.
Had to take a section of my pipe out, complaining “who have thought of putting a copper piping there for the drain…”
Didn’t have the replacement available.
Had to take 30 off to go to the hardware store (and probably for food).
Only one dude came back.
He “restored” the pipe he had to take out.
Tried to drill some more – to no success.
By then it was like around 2 PM already.
He has counted up to around $400 but said won’t charge me since he’d have to come back (I requested Saturday) to actually go get on the roof.
Wrapping up, he was like, let’s test the drain, to see if they were able to make the difference.
Sure. Turned the water on. Oh, look, joy – it’s not backing up!
Great, won’t have to come back!
We go downstairs to finalize…
And I’m hearing some strange noise down there…
Apparently the water is raining down from the light fixture in my hallway.
Oh $%#.
So I guess you are gonna have to come back. Took a picture and quickly skedaddled. Said the dispatch will give me a call for the details for Saturday.
Waiting. Getting tired and pissed off. Called them myself.
They are like oh ****, that one… let me call you back.
10 min later their boss calls.
Told him the whole thing.
I could tell he was kinda pulling his hair out on that side.
The plumber dude apparently failed to tell him about the light fixture shower.
He asked me for the pictures which I have provided.
There was 2 large towels’ worth of water collected on the floor. There were moist lines along the ceiling and around the fixture (not too bad). Obviously I’m not turning that light on.
Something along “we may end up having to pay YOU” was mentioned.
Fast forward. They didn’t come on Saturday to continue, however it was arranged with their boss to come for the assessment next Monday.
He came next Monday and basically shifted the narrative that the drain pipe is just old and it just up and fucked itself. That this is not the common line issue. That their tool could not have hurt it. That it's gonna take having to cut out sections of the drywall to find where the pipe has busted. That it will come to thousand$ if they are to do all of that. Basically he's the expert and it was his word against mine. He suggested I think about what I want to do, that it would be a lot cheaper if I were to start cutting holes in my walls myself in order to locate the leak so it would be cheaper for me in the end. He also recommended to change the old cast iron drain pipe altogether. He did concede that he would be willing to reduce the bill to the minimum of $150 even though I have received an electronic bill for around $400 from them later.
So, I'm hoping to hear reactions and recommendations from the professionals on how should I proceed from this point on.
Pay to have your old pipe replaced so you can use your lavatories upstairs.
That’s how you should proceed.
Part of the problem is that I feel like the Duck Duck boss is BSing me about them have nothing to do with the leak. I myself work in a repair industry, a very different kind. I know the technique of shifting the blame to the customer. But I'm not familiar with the rooting devices/plumber work ethics/should they be held responsible for effing up my pipes in the process. This is a big part of the question. They have wasted my whole day, destroyed my drain pipe, didn't clean the clog and still want their $400.
There was a problem with your pipes or they wouldn’t have been there.
If there was a common pipe leading to the roof one way the could have assed the problem with a camera, the pipe may have been compromised and clogged but both parties would have seen these issues,cleaning drains is really a specialty some plumbing co. Do clean drains, but drain cleaning co doit all the time and have more equipment then a plumbing co would carry
If it were me, I'd ask myself this simple question:
  • Were those pipes leaking before "the drain cleaning specialists" arrived?
After that I'd ask myself another simple question:
  • Did breaking off part of the (spring-steel pipe cleaning) snake in the pipes, while trying to unblock them, have anything to do with why those pipes are now leaking onto my ceiling?
After that, I'd ask these professionals' boss, foreman, or company owner, the same questions.
Then I'd ask the Condo's Attorney, the Condo's Insurance Company, and My Homeowner's Insurance Company the very same questions. Last, I'd sit back, nibble on some popcorn, and watch the drama play-out.
Fun for the feeble-minded, except that you have to deal with the results of these ....ummmm... Pros.
Good Luck !!
Drain line clogged up, person calls drain cleaner , drain cleaner runs cable through pipe, cable bit breaks……. pipe leaks……..
Now it’s the drain cleaners fault your pipes are leaking.
It’s all their fault……..
Drain line clogged up, person calls drain cleaner , drain cleaner runs cable through pipe, pipe leaks……..
I respect you, but you did leave out small item... They broke off end of their snake. Happened to a plumber I hired once, but I was too young and dumb to figure out why he left 2 minutes later - "No Charge, since I didn't fix it" LoL.
Everybody buys insurance, so, let the insurance companies fight about who's at fault, if anybody. That's one of the things we pay them for, so let them do their job. Also, we don't know if that Condo's age 5 or age 50, and I guarantee the insurance company fighting to pay out $0.00 on their end, will say that age & condition doesn't matter, blah blah blah. (( And it's like a divorce, where we're only hearing one side of the story ))
Plumbing drain cleaning cables and bits can break, it’s not necessarily the plumbers fault.
The drain is the problem, that’s why the plumbers were called.
Some people think others are responsible for their crappy pipes when things don’t go the way they think it should.
Also, there is a transition between copper and cast iron someplace in the drain system. Anytime one puts a mechanical cleaning device inside a drainpipe, damage can be done. And when they broke off their snake, not only is it plausible, it seems actually likely that they caused the problem, IMHO.
I totally agree with watching the insurance companies fight it out. It would be fun to be in the negotiation room to see them fight. LOL
I edited my post and fixed it. Same difference.
If it’s cast iron……the bottom could be rotten and the drain cable bit poked a hole in it and then got caught in this hole and snapped.
Then of course the leak starts because of the hole.
Drain machines will not damage good pipe however it will find weak spots in the pipe and can penetrate those weak points.
It all points back to the condition of the pipe……again that’s not the plumbers fault.
If a mechanic tried to take your wheel off of your car and the studs broke off when he tried to take the lug nuts off…….
Is that the mechanics fault ?
They were fine before he touched them, right ?
Or did the mechanic do his due diligence and your lug nuts were over tightened?
So was there a problem with the drain and the plumbers that came to work on it happen to just be the unlucky ones who took the job or did they “ damage “ your old clogged up drain pipes ????????
Good luck with that.
I'm changing my opinion a bit after remembering quenellefl saying, "I probably have spent around $50 altogether on Draino to get them working in the past."
Even though the makers of Drano say their product is safe for metal pipes, many experiences indicate otherwise. And lead and tin aren't friends with Sodium Hydroxide. So, with at least some copper drainpipes, some damage could have already been done.
But still, I would like to see the briefs of the insurance company lawyers. LOL
These pipes are the Condominium's problem, not the unit owner who posted here. Unit owner usually owns either from the sheetrock, or the paint film *on* the sheetrock, in, to space in the apartment/unit.
Everything else, structure, roof, hallways, stairs, pipes, wiring, etc., owned and maintained by the Condo.
>>> Would like to see the briefs...
Amount here too small for attorneys to be involved.
$5k to maybe $10k ?
I re read your 1st post in your 1sy few paragraphs, you mention that it's the HOA's responsibility, so really, the plumber/drain cleaner should be contacting the HOA board members, and they should be contacting you or other residents for access and repair options ,and payment is the HOA responsibility you should take your self out of the equation and refer all calls to HOA board
