Hello all!
Having some sewer smells coming from the basement which takes over the whole house. Had a scope run through the main sewer line out to the road, nothing blocking it, everything looked good. Had it snaked by a professional anyway, it went right through and didn't pick up anything. He then added some sort of detergent/disinfectant in to the lines and sinks/toilets which helped for almost 24 hours, but its back again. I did my own smoke test by putting the smoke bomb in my cleanout in the basement. Didn't see any smoke coming from any of the lines. (Some of the stink pipe is cast iron) There was a little smoke coming out the stink pipe out the roof, but a lot coming out my floor drains. With the house being built in 1905 I guess this was kind of common for floor drains to tie in to the main sewer line?? Would the majority of the smoke coming out the floor drains indicate the stink pipe is plugged? I'm at a loss and everyone I talk to just spins me. I keep a basement window cracked which helps tremendously but its getting cold here in Michigan and we need to get this figured out. ANy help or ideas are greatly appreciated.
