Jamesecolli
- Joined
- May 30, 2018
- Messages
- 4
- Reaction score
- 0
"A pipe burst in my condo. A plumber said it's because the builder used "house pipes" instead of "industrial pipes". Is this common?"
he talking about the different thinkness of copper type m was against mass code in 1986 for potable water type l is most common...there is a type k that was used a lot around this area a long time ago....its also used in a roll rather than stick whe installing a water service
type m is mostly used for heating systems so m is thinnest type l is a little bigger in wall thickness...then type being the thickest there is also dwv....a thin wall copper used only in waste and venting more in venting in my area......
Separate subject but good information!Doesn’t matter L or M. If you have well water in some places (I live on Cape Cod ) and the groundwater literally eats through copper pipes in a couple years. The telltale sign is green stains under faucets. That’s actually the Copper pipes being eroded from the inside. I replaced ALL the copper piping in my home twice. ( some pipes three times) until I completely gutted all copper and switched to PEX. I bought the expansion tool on eBay. It’s quick, easy, and error free. My neighbors have a plumber come to their home at least once a year to ‘fix those leaks’ in the copper pipes. Again. And again. And again.
I can’t believe in the long run that adding the initial expense of a treatment system PLUS the cost of operating and maintaining it would be more economical than removing and replacing the copper with PEX. Although the average homeowner must pay the plumber to install.Acidic water can be treated with a neutralizing filter. This is a mineral based material that dissolves and brings the pH to 7.0 or higher. Cheaper than replacing all the copper in the house. Of course if your pipes are already weak from corrosion, it will only put off the inevitable.
