Good day.
I would like to put a hydronic heating boiler SIME at my home for hydronic heating. The best place for it is close to my gas water heater (BOSCH). I would like to use the existing gas pipe (which is feeding my water heater with natural gas) to feed the boiler as well. The pipe is 3/4 of an inch. My questions are:
1. Will there be enough natural gas in case the water heater and the boiler will work at the same time (so one device will not slow the other devices performance) using one pipe or should I get a separate line from the gas meter (which is about 15 meters away on the other side of the house)?
2. In case there is enough gas for both devices to work, how much will it cost (roughly) to make a line for the boiler from the existing one about 1,5 meter long with a valve?
3. Can somebody recommend a good gasfitter in the north west of Adelaide for a job like that?
4. Does anybody know where can I obtain information about my gas connection is it high speed or nor? (I have herd that it might be important)
Thank you for your time and help.
