Olmec Sinclair
Hi all,
(apologies in advance for metric.... if this is an issue I can do conversions, hopefully you get the general idea)
I have a length of about 80meters of 60mm diameter poly pipe that collects water from a small stream and transports down a creek bed and then back up onto a terrace. The height difference from inlet to outlet is about 0.25meters. Height difference from inlet to lowest point is perhaps 15 meters.
My problem is that the pipe only ever runs at about 20% capacity. I am assuming there is some kind of airlock in the system... or could it be due to pipe friction and small elevation change?
Considerations / observations
- The first 15 - 20 meters of the pipe has been covered by debris, could be a problem under here
- There is a ball valve at the lowest part of the pipe so I can drain. If I open this I get a very powerful stream of water (full 15m of head).
- Opening the valve and slamming closed it makes an impressive hammer but doesn't
