Hi folks,
I called a plumber more than 10 times for the same issue. He was bleeding the airlock from the system but 3 - 4 weeks later or so....the airlock has been created by itself again. It's not only into 1 particular riser. Now, almost every unit on the top floor is effected (kitchen and bathroom). The plumber said, maybe because of the booster pumps were stopped but they are not and running all the time. No water or power interruption happened in the building. The second plumber said maybe there is a cartridge but as I said the problem is not only into 1 riser. I had a HVAC guy in beginning of the year. He replaced a faulty hot water tank relief valve for this particular zone. Is it possible that airlock to come from the hot water tank? Somewhere at that time the problem appears? What do you think? Thanks.
