dwplumbing
I have a 2 pipe Jet well pump pulling from a 60 foot well and it is currently feeding into a pressure tank with a pressure switch @ 30/50 PSI .
Could I change the output from the well pump from the pressurized tank to fill an unpressurized holding tank?
I just want to be sure that the output pressure on a well pump like this does not effect the pump action out of the well with the 2 pipes.
I am assuming that there is internal isolation in the pump between the input side and the output side, if there is not I would think I would damage the pump long term?
Does that make sense?
Thanks,
Dave
Thanks,
Dave
