Hi there,
I have a very slow drain problem in my tub drain. I bought a hand auger to try and unclog is but even with the drain stopper turned to the off position it won’t go past a certain point.
I tried to remove the handle and fixture on the drain stop but was unable to. I was thinking that it is not allowing enough water to flow even when in the off position.
If you have dealt with older plumbing like this could you tell me if the stopper could be my problem? How would I remove it to be able to adjust it?
