Best option would be to use a carbon based whole house filter. I personally like the 20" size housing but due to your location restrictions, you may have to go with a 10" housing system.
Carbon based filters are meant to filter out chlorine, taste and odor and typically carry the NSF/ANSI 42 standard which means they have been certified to meet the standards for chlorine, taste and odor reduction.
You can get the 10" whole house filter housing with 1" ports or 3/4" ports. The Big Blue filter is probably one of the most popular, which you can get in 10" or 20". You would then pick whatever kind of filter you want, but for Chlorine, Taste and Odor you would want to got with a carbon based filter.
If in doubt, take a sample of your water to a testing lab and have it tested to see whats in it, then test it again after the filter. You can also contact your water company to see if they have a print out of what is in the city water.
