I've adjusted the chain and cleaned the flapper. That fixed the problem of running water from occurring very frequently. However, two things continue to occur very irregularly.
1. Water will start to dribble from the filler tube into the vertical receiver tube well after the toilet has been flushed and water has stopped filling/running. When I catch it, flushing again generally resolves the problem. There is no 'slack' in the lever so jiggling the lever is not an option.
2. More rarely and as of the last couple of months, after flushing the tank will emit a sound like a suction (sort of). I've never heard this sound before from a toilet but it may very well be due to the type of flush assembly.
Are these indications that the assembly needs to be replaced?
Mark
Mark
