dvitale71
Hi all,
I noticed a fast drip coming from the ceiling of my basement (not finished). I searched google and tried some basic troubleshooting but wanted to post my issue here in hopes of your support.
I was able to identify that the leak is coming somewhere from the hot water supply line as it shoots up to my second floor bathroom.
For now, I've shut the water off to that bathroom until I can figure this out. My best guess is that it has to be a fixture of some sort. I'm no plumber but my educated guess is that when the water supply is active (faucet off), I assume I would see some sort of leak if there's a pipe crack. Again, if the water supply is active (faucet on), then I see the leak.
My next step is take apart the single level faucet from the tub. Is that correct? Is there anything else I should try before I need to call out a plumber? Obviously, I'm trying to save money and hoping not to tear up my walls to find the issue.
Any help is appreciated!
- I ruled out the bathtub drain and replaced that today.
- I also cleaned around tub and placed new caulk around the tub area
