mcf57
So, I recently replaced a toilet in a basement bathroom. I have done this many times so this has never been an issue. As before, I first turned off the water to the toilet from the valve near the wall. Then disconnected the water supply line from toilet. Removed the old toilet and replaced with new one. I didn't put the wax ring/seal on just yet as I wanted to make sure everything fit and lined up properly. hooked everything up and turned the water back on. Tested, check for leaks and all was good.
On to putting the wax seal on. I turn the water off from the wall. Flushed to get most water out of tank and used some towels to get the rest. When I started to unscrew the water supply line (from the toilet tank), water started leaking and flowing out of the line coming from the wall. I checked and turned the water off as tightly as I could. Its still flowing though when I try to remove the water supply line. I tightened it back up to the toilet and all is good and no leaking.
Since it still needs the wax ring, I am not using it just yet. I can turn the water off from the street to fully get this done, but did something wear out in the wall valve? does something need to be replaced in the wall shutoff valve (circled in picture below). Maybe some sort of ball, bearing or something else? Not sure.
