Thanks for the help. I think it was the rental manager. I will be adding a regular ptrap and moving the drain box over a few inches.Between the outlet of the trap weir and the vent opening must be two pipe diameters apart. In this case that would be 4”. Not 4” of pipe, but 4” developed length. That appears correct, maybe not. Measure it.
They used green transition cement to transition between the abs and pvc. It wouldn’t meet code in my jurisdiction but in some jurisdictions it might. I’d fail it on workmanship clause. It could be argued either way. They also used transition cement on the abs to abs tee connection, I doubt the manufacture would approve but maybe they would. You’ll have to check. They also used transition cement on the pvc to pvc connections. I doubt the manufacture would approve, or the plumbing code.
The 2” unshielded rubber coupling wouldn’t pass in my jurisdiction.
