Plumbing Diagram
JWT
Jul 6, 2022
Oregon
I want to replumb a cabin to include a valve for recovering grey water to use for irrigation. Will the layout per the attached diagram meet code?
  • Plumbing Diagram.pdf
Not UPC (all I know).
A few non grey water tips first.
You only need a 3" drain for any home with up to three WCs.
1.5" vents only needed for everything but a WC.
Kitchen must have 2" drain and a cleanout...1.5" vent is fine as before.
The total vent area must equal the largest required building drain...so, total vent area is either 2- 2" vents plus an 1.5" or all into a 3" stack...but what you drew would still work, just not meet UPC.
No tee's on back for drain from WM, use combo.
I'll send a photo of UPC req'd graywater system.
This is how UPC requires greywater
We just dump it in the streets around here……..
Sewer overflow after overflow. It’s baked into the cake around here, no big deal.
Thank you for the response and greywater diagram, breplum. So if I make the changes you suggested this will meet UPC? Also, what does WM stand for and what is a combo?
Washing Machine = WM
Combo is a fitting consisting of a WYE and an 1/8th (45 degree) bend. In the case of most 2” drains (kitchens, laundries) 1-1/2” vents are allowed as long as the total vent area allowance is met for the building.
Thank you again for your help.
I've attached a revised schematic based upon your feedback. Will this one meet UPC?
  • Plumbing Diagram 2.pdf
