We'd like to install a shower over an existing slab floor; 9 feet from the shower drain, the slab ends and there's a good drop to existing lines. (Unfortunately the only window, in a load-bearing wall, prevents locating the shower at the slab edge. No closer drain is available unless we tear apart the soil stack.)
By my computations, we'll just clear the sill plate with a 2" line at minimum slope, provided its centerline is 5" above floor level at the shower drain.
1. Is it reasonable, and Code, to raise the shower pan 6" or so above floor level? (It appears our pan's entry rim will be another 4" above that.)
Placing a step before the shower would mean raising the toilet as well. (It's a small bathroom.)
2. Can the trap be located nine feet from the fixture, prior to connecting it to anything else? How tightly against the pan might we expect to be able to bring out the drain line, with or without a trap there?
3. Is it permissible to remove a short slice of the sill plate, bolting the ends to the cement? That would lower everything by 1-3/4".
The vanity is against the exit wall; on the other side is the laundry. There's plenty of drop below the laundry wall.
Thank you for any advice you can offer!
