J JoelR New Member Joined Jul 25, 2023 Messages 3 Reaction score 1 Location Cedarpines Park, CA Jul 25, 2023 #1 I am plumbing a new bath and adding a bi-directional cleanout at the same time. This is in a crawlspace with a 60" ceiling. My question is, does it matter which direction the cleanout wyes point? Should they be 90 degrees to the ground, or point down? (See pic. Drain will continue to the right.)
T Twowaxhack Currently in the Lab conducting research Professional Joined Feb 9, 2021 Messages 14,096 Reaction score 6,596 Location United states Jul 26, 2023 #2 Cut that out and install this in the upright position. What you have will fill with sewage and is improper. https://www.homedepot.com/p/NIBCO-4...leanout-with-Plug-Test-Tee-C5814HD4/100346483
J JoelR New Member Joined Jul 25, 2023 Messages 3 Reaction score 1 Location Cedarpines Park, CA Jul 26, 2023 #3 Thank you #Twowaxhack. It's not glued in yet. Wouldn't this make more sense? https://www.homedepot.com/p/Charlot...x-Hub-2-Way-Cleanout-ABS004480600HD/313834553 The only reason I was hesitant to orient it up is that there is very limited space above it.
G Geofd Moderator Staff member Professional Supporting Member Joined Jan 20, 2018 Messages 4,994 Reaction score 1,164 Location Boston, Massachusetts Jul 26, 2023 #4 That is why the picture/fitting shown will do the same thing for less money the fitting you show is for buried piping
J JoelR New Member Joined Jul 25, 2023 Messages 3 Reaction score 1 Location Cedarpines Park, CA Jul 26, 2023 #5 Awesome - thank you both!
T Twowaxhack Currently in the Lab conducting research Professional Joined Feb 9, 2021 Messages 14,096 Reaction score 6,596 Location United states Jul 26, 2023 #6 If there’s no room then move the clean out to where you have more room. Turning the fitting down is never an option.
