bent240lv
Hello
Today I had my gas for my pool heater hooked up. Prior to this I had a gas line Tee'd off of the heater and run underground about 15ft for a firepit next to spa.
When the plumber came today, he said that the line for the firepit is not up to code and that I should have it inspected. He said his main reason is that the line is not sleeved. The pipe the plumber who did the work used was of the green coated variety but apparently it still needs to be sleeved.
He said that If it fails inspection then the original plumber would be responsible for all repair work needed. This would involve having to have the pavers redone.
Does anyone have any experience with this? Or have any suggestions as to how I should procede?
Currently the pipe in question is being pressure tested. It was at 60psi, over 4 hours and it has already dropped to 50psi
If it is not to code I would like to get it redone.
Thanks
Thanks
