Hey guys the bladder in my old tank went and pump was running every time I turned on the water. I swapped it out with a new tank same size as the old one. Now my pump does not turn on every time I turn the water on but I still feel it is short cycling. Pressure in tank is set at 38psi. My pressure switch is a 40/60 switch. When I turn my water on the pressure works its way down to 50psi and then drops almost instantly below 40 and pump kicks on. I think I somehow got air trapped into the water side of my pressure tank when I filled it after install and that is causing my issue. Any advice on how to get air out of the water side and properly filling it with water? When my pressure gauge reads 60psi the tank still feels very light like it's only holding a few gallons of water. It's a 40 gallon tank. Any advice is much appreciated.
