Up until recently, the plumbing in my 15-year-old house worked flawlessly. In the last week I have noticed a septic smell coming from the washing machine drain. The drain itself is approximately 3 feet from the floor, goes down below the floor into a U-trap, then into a vertical-T pipe (drain and vent I assume).
I have done the following:
1. I went up on the roof, found two drain vents, and flushed them both with water from the hose. It did not help.
2. I ran Drano in the washing machine drain itself thinking there may be stagnant water in the trap. It did not help.
What am I missing? I suspect the drain vent has a Y-splitter on it below the roofline that is clogged. If so, how do I force water into the clogged split when I clear it?
The washing machine drain is located not far from our dining room/kitchen and the smell is becoming overpowering. Any help and advice is greatly appreciated. Thank you.
