Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > tub P trap in a tight space?
Thread Tools Display Modes
Old 11-05-2010, 03:34 AM   #1
Default tub P trap in a tight space?
Can anyone figure out how to get a p trap installed in such a tight space? My slab house was built in 1972 and the previous owner put the tub drain/overflow directly into the existing cast iron drain via a rubber gasket connection. I am guessing that there is no p trap in the cast iron piping...How would you bring this up to code? The concrete slab has been chipped away from the cast iron drain pipe. We installed a vent pipe about 6 inches from this overflow pipe. Thevent is all ready to hook up, I just can't figure out how to fit the p trap in.
ps ...I even called a plumber and he said he had no time for something like this.
I have attached two images of the drain and tub. I scoured the web and could not find anyone with a similar problem... Click image for larger version
Copper is offline
Old 01-19-2011, 08:33 PM   #2
NotAnotherRep's Avatar
is there enough length of pipe between the bath and soil pipe to fit a running trap
NotAnotherRep is offline
Old 01-20-2011, 01:57 AM   #3
Easily Amused
Mr_David's Avatar
Liked 907 Times on 736 Posts
Likes Given: 597
There probably is a p-trap buried below.
If you dig down in to the hole ( If you can ) you just may find your p-trap
I made a quick sketch. There only 2 ways that I know how to get the access you need to work on this and it's not easy.
Remove the bath tub, which is probably not likely
Or get a jack hammer and bust out the concrete from the side you took the picture. You have to be careful so you don't break any drain pipe.
I don't see the vent in your picture but it's probably close by in the wall.
Good luck. That is not and easy job even for those that know how.
Are you having a problem with the drain?
a.k.a. Krazedav
Mr_David is offline
Taps too tight emilybieman General Plumbing Help 2 06-11-2012 09:38 PM
Tight faucet handle yong321 General Plumbing Help 3 05-24-2012 12:15 AM
Bolts tight put toilet is still lose matt2829 Toilets and Sinks 2 05-13-2012 01:40 AM
Mystery Moisture in Crawl Space NEED HELP porjohn General Plumbing Help 6 08-06-2010 12:36 PM
Newest Threads
