Possible leak at Pressure relief valve
MikeGlosta
Jan 16, 2016
10
Facts:
Bradley White Electric water heater - 50 gal
wet floor around heater
removed both upper and lower element covers to check element seals - both good
discovered line of water dripping from above the lower element - the upper element is NOT leaking
Since the inside tank is domed is it possible for the Pressure Relief Valve to LEAK at the connection to the tank, beneath the outer shield, unseen? I don't know where else a leak could be coming from.
I don't want to take the PRV off unnecessarily. The valve works fine (tested)
look at the pipe connections, hot, cold, anode, T&P see if any sign of wetness
you already checked stat, if no wetness it is the tank, if their is wetness, pull/replace nippples
if you can not see the tank, pull the sheetmetal jacket. or cut with tin snips
