johnnytucats
We've got an old American Standard equipped bathroom from the late 1920's that's still in great shape.
The one thing that irks me is the toilet. The water supply comes out of the wall into the top rear of the tank...through a hole in the tank. The tank is mounted directly to the wall as it was designed to be.
The flush mechanism is a brass thing that wears out every two or three years and now costs up around $180 or more to replace. Surprisingly, it's an easy part to find for me because I have a supply house less than a mile from here that stocks the old stuff.
I'd really like to do a re-piping job from the inlet down and across the tank (under water) and back up a bit to a fitting that will work with one of the new, standard and inexpensive flush fill mechanisms.
Anyone ever seen this done? I went to Home Depot and couldn't even find a fitting the same size as the bottom of one of these flushers. So, I haven't even checked on what would work with the inlet.
