Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Project Display > PEX manifold system
Thread Tools Display Modes
Old 01-06-2010, 11:09 PM   #1
bradthebard
neither a bird nor plane
bradthebard's Avatar
Default PEX manifold system
In the process of finishing up replumbing an old house with pex.
Here is the central manifold
A shot of the pex runs in the joists.
The tankless water heater that will feed it.
And here is the upstairs hall closet I converted into a laundry closet.
Those are Sharkbite connectors for the hot and cold water, if you can see them. Worked great. No leaks (the threads above them leaked a little though) and installation is literally a question of pushing them on. For small projects they are great, though a bit cost prohibitive on larger ones. I used a sharkbite on a hot water line for three years at the cabin and it never leaked a drop.
bradthebard is offline
Old 01-06-2010, 11:23 PM   #2
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
That is pretty sweet I have never seen PEX used.
Chris is offline
Old 01-17-2010, 02:51 PM   #3
Otahyoni
Established Member
Otahyoni's Avatar
Liked 13 Times on 11 Posts
Likes Given: 1
So PEX just pushes together? Sounds like the air lines on trucks...
How long is it expected to last versus CPVC or copper?
Otahyoni is offline
Old 01-17-2010, 03:41 PM   #4
SilverBack4Jack
Always Learning.....
SilverBack4Jack's Avatar
Several different connector styles for pex. The main one used in my area is the crimp style.
Well you see what had happened was....
SilverBack4Jack is offline
Old 01-17-2010, 03:55 PM   #5
nhmaster3015
Master Plumber
nhmaster3015's Avatar
Don't use metal hangers on pex'
The holes drilled through the joist need to be in the middle 3rd of the joist
When in doubt, hire a licensed professional
nhmaster3015 is offline
Old 04-06-2010, 12:15 PM   #6
PlumbingTheCape
Looks good
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
PlumbingTheCape is offline
Tags
PEX, manifold, tankless water heater
Jerry rigging a shower manifold Jimbo13 General Plumbing Help 8 07-07-2012 02:59 AM
Pex Manifold TheNapster87 General Plumbing Help 3 06-04-2012 09:24 PM
PEX manifold v none gstettner General Plumbing Help 3 12-14-2011 03:23 AM
Supply Manifold for Copper supplies? csutterer General Plumbing Help 3 02-03-2011 12:31 AM
Detention system Chris Project Display 4 01-09-2010 03:34 AM
Newest Threads
