Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Septic Tanks > Length of pipe in septic tank
Thread Tools Display Modes
Old 06-28-2014, 02:15 AM   #1
Likes Given: 2
Default Length of pipe in septic tank
can anyone tell me how long the inlet and the outlet pipes should be in a septic tank also are they to be the same height at the top?
poopinleachbed is offline
Old 06-28-2014, 03:35 AM   #2
Zanne's Avatar
Liked 190 Times on 169 Posts
Likes Given: 3382
I'm trying to look up if there is a length.. I know that the tank needs to be a minimum of 10 feet from the house/dwelling.
According to one source, the outlet should be at least two inches lower than the inlet. Inside the tank there should be at least a four inch space between the end of the inlet pipe and the concrete baffle. But that source was from 1982. I'm searching for something more recent.
I don't know about the pipe lengths. Hopefully someone who knows for sure can respond.
Zanne is offline
poopinleachbed Likes This
Old 07-02-2014, 03:57 AM   #3
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
In the concrete tanks we install the inlet will vary and really only needs to be a clear opening, on the outlet we usually have 4-6" and a tee installed with a section of pipe going downward to keep any solids from leaving the tank.
Chris is offline
People Like This
Boiler loop circulator pump sizing for "equivalent length of pipe"? JohnDS General Plumbing Help 1 11-15-2013 05:28 AM
floating septic tank IFIXH20 Septic Tanks 11 06-30-2012 12:45 PM
Septic tank question.. rtlplumbing Septic Tanks 2 03-21-2012 06:06 PM
Septic Tank - baffled jreist Septic Tanks 9 09-21-2011 08:29 PM
How big is my septic tank? Mania64 Septic Tanks 5 05-25-2011 07:41 AM
Newest Threads
