Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > No pressure at only one location
Thread Tools Display Modes
Old 05-10-2014, 12:05 AM   #1
Ben_IV
Default No pressure at only one location
I have noticed the water in the door on my refrigerator running slow and it isn't making much ice either. started checking things, wasn't the filter, unhooked the water line going into the frige and put it in a bucket and found that water was just trickling out. blew out the hose with no change so my next step was to replace the valve in the wall. well that didn't change anything either. obviously there must be some sort of blockage or leak in the pipe leading to it, though my water bill shows no signs of extra use and the faucet in the sink runs fine and so does the washer hookup on the other side of the wall. I would really appreciate any input as to what could be the problem and how I could go about fixing it, thank you in advance.
Ben_IV is offline
Old 05-10-2014, 12:55 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 410 Times on 324 Posts
Likes Given: 258
Post a picture of the line and where it connects to the valve.
John
johnjh2o is offline
Old 05-10-2014, 02:26 AM   #3
Ben_IV
If you are referring to the line on the house side of the valve its inside of the wall and all I can see is a bit of pipe and the 90 deg elbow that turns up and the valve screws directly into that.
Ben_IV is offline
Old 05-10-2014, 03:08 AM   #4
SHR
Liked 60 Times on 46 Posts
Likes Given: 109
What type of pipe in the wall? Copper, steel or pex?
SHR is offline
Old 05-10-2014, 05:54 PM   #5
Ben_IV
Copper, runs into a brass 90. About 8 feet down the wall on the other side is the washer hookup so im guessing it ties into that, no problem with the washer though. House was built in 1982 I have never heard of a blockage in a fresh water line before.
Ben_IV is offline
Trap Location jpm6621 General Plumbing Help 4 12-21-2012 12:44 AM
New Tub vs. old r.i. location Oldpuck Showers and Tubs 10 12-12-2012 02:42 AM
Anode Location? philipk65 Water Heaters and Softeners 5 10-22-2011 03:10 AM
trap location mijoda52 Toilets and Sinks 3 09-21-2011 11:53 PM
washer drain location snrusnak General Plumbing Help 7 06-05-2011 04:27 PM
